I’m Writting because I’ve problems with the botton Unread Next and Unread Before. Sometimes there’re unread documents and the Lotus can’t find it and put there aren’t unread documents after a long time and there’re unread and the most curious if you exit the Lotus Client and entry again you can find the next unread in the same category but not in the others category in the same view.How Can I solve this?.
It’s quite curios.
Yours sincerelly, Roger.
