Problem agent planned
Hello,
I have an agent planfié which updates a field number.
The officer manually run function very well, but planned numbers after the point necessarily go to zero
(Ex: 30.25 after exeution of the agent gives 30.00).
The officer planned locally is working well.
I installed as a client on my server, manually run everything is ok.
I deduced that the problem is with server DOMINO.
Do you have an idea?
