Problem after upgrade Domino 8.5.1 FP2
After upgrade Domino 8.5.1 FP2 for Windows server 2003 X64
Then, My lotus traveler (using same server) have running Traveler task (nTraveler.exe process is 99% all the time after first sync) and my user can’t sync to the server.
Error log while I’m sync
Notes Traveler: SEVERE CN=Danu Hunskunatai/OU=IT/OU=MFG/O=UNIPRO Internal Error: Debug Data: NAMELookup error = 00000310: ‘Specified item is not present’
Task status
1438:0002 Lotus Traveler Running: 2 of 4 users active. Completed 0 device and 8 prime syncs. [nTRAVELER]
If shutdown Traveler Error
Notes Traveler: SEVERE *system Thread DS-002[CGHH3AAA][2] was not shutdown properly by calling destroyData()
Compact database
06/05/2010 10:01:21 PM Compacting LotusTraveler.nsf (IBM Lotus Notes Traveler), -c -s 10
06/05/2010 10:01:21 PM Error compacting LotusTraveler.nsf: Database is currently in use by you or another user
Finally, I upgraded domino server to 8.5.1 FP3 and Traveler 8.5.1.2 (lastest). but the problem still occer.
IF anyone have an idea to solve the problem please help Thank you inadvance.
Subject: Fixed, I think
Still very early, but I uninstalled Notes Traveler and reinstalled NT 8.5.1 (not FP2). Everything is working normally now. It’s been working reliably for about 2 hours now. Task Manager shows the ntraveler.exe application as consuming 0% most of the time, with occasional spikes to 53% or so. This is dramatically different from FP2, which ramped up to 50% of CPU utilization (essentially pinning one core) and never backed off.
Hope this helps you.
Subject: Thanks
Thanks, Tom. I will try.
Subject: Same problem
For the past few days I have been wrestling with exactly the same problem. Initially my nTraveler.exe task was consuming 99% of CPU. After several reboots of the Domino server it is down to 50%, but runs constantly at 50% even when nothing of consequence is going on. If you find a solution to this, please post it.
Tom
