Problem adding person using LDAP
Hello everybody!
After upgrade my Domino server from R5 to R6.5 we cannot do add commands to LDAP, we just can search and update.
After turned on LDAPDEBUG I got the errors below:
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> LocateEntry: cn=User asdasd/o=bpic
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> Searching in database C:\Lotus\Domino\Data\names.nsf …
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> Type of search: Base DN Search
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> … Using ($LDAPRDNHier)
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> LocateEntry: o=bpic
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> Found matching entry, Note ID: 4918
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> Tree checking passed, parent (o=bpic) exists
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> Failed, ambiguous DN specified, operation aborted
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> CLDAPException thrown at s_add.cpp:339 - Failed, ambiguous DN specified, operation aborted
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> CLDAPException caught at s_add.cpp:1278 - Failed, ambiguous DN specified, operation aborted
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> LDAP Add return result: Operations error
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> Return Result State
21/06/2004 06:55:16.78 PM [0974:0014-1054] LDAP> StateReturnResult returning resultCode 1 (Operations error)
Any help will be apreciated…
Tks.
Subject: Problem adding person using LDAP
Are you writing to the main or a secondary directory?
The configuration documents in each directory, LDAP tab of Default config doc, what is the rule setting it uses when it finds multiple entries? Don’t modify any? I beleive it should be Modify first match.
Subject: RE: Problem adding person using LDAP
Worked for me…
Thank you!
