Problem accessing AD through ADO/Lotusscript
I have a piece of VB/VBS that works perfectly as a vbs and also in VB that does a lookup to Active Directory through ADO. The problem is in LotusScript. I’m getting a “Type Mismatch” error when it tries to execute objCommand.ActiveConnection = objConnection
I suspect that the ADODB.Connection object isn’t getting instanciated correctly. Does anyone have a guess why LotusScript is choking on this where vbs and vb have no problems on the same machine?
Here is the code:
Dim objConnection As Variant
Dim objCommand As Variant
Set objConnection = CreateObject(“ADODB.Connection”)
objConnection.Open “Provider=ADsDSOObject;”
Set objCommand = CreateObject(“ADODB.Command”)
objCommand.CommandText = _
GC://dc=xyz,dc=com;” & _
“(&(objectCategory=person)(objectClass=user)” & _
“(sAMAccountName=sdskunaa));” & _
“sAMAccountName, distinguishedName;subtree”
Set objRecordSet = objCommand.Execute
If objRecordSet.RecordCount = 0 Then
Wscript.Echo "The sAMAccountName is not in use."
Else
While Not objRecordset.EOF
		MsgBox "sAMAccountName = " & _
		objRecordset.Fields("sAMAccountName")
		MsgBox "distinguishedName = " & _
		objRecordset.Fields("distinguishedName")
		objRecordset.MoveNext
	Wend
objConnection.Close
Subject: Working agent to verify a user name is unique in the AD Global catalog
Thanks to Dallas I got my code working so I thought I’d share it with the group. Given any user name it will do a look up against the Active Directory Global Catalog and confirm that the name is unique in the forrest. The base code is directly from Microsoft with a few minor modifications to make it work in LotusScript. You just need to modify the queries to make it work in your environment.
Here is the link I got the original code from at MS (it has some other good info)
http://www.microsoft.com/technet/scriptcenter/guide/sas_usr_seaa.mspx
Sub Initialize
Dim Test As String
Set objConnection = CreateObject("ADODB.Connection")
objConnection.Open "Provider=ADsDSOObject;"
'test = objConnection.DefaultDatabase
Set objCommand = CreateObject("ADODB.Command")
Set objCommand.ActiveConnection = objConnection
'Modify the next line’s dc and username (sAMAccountName) to match your environment
"<GC://dc=xyz,dc=com>;" & _
"(&(objectCategory=person)(objectClass=user)" & _
"(sAMAccountName=axelrod));" & _
"sAMAccountName, distinguishedName;subtree"
	Msgbox "The sAMAccountName is not in use."
Else
		Msgbox "sAMAccountName = " & _
		objRecordset.Fields("sAMAccountName").value
		Msgbox "distinguishedName = " & _
		objRecordset.Fields("distinguishedName").value
	Wend
objConnection.Close
Subject: Works for LDAP query against other directories (Sun, Netscape etc)
This code works for LDAP query/lookup against other non AD directories as well.
All that changes is
objCommand.CommandText=
ldap://dc=xyz,dc=com;” & _
“(uid=axelrod));” & _
“uid, cn;subtree”
uid,cn depends on the schema of your directory
Just check the return value of objRecordset.Fields, it may be a array instead of string.
Subject: RE: Working agent to verify a user name is unique in the AD Global catalog
I am getting error at Set objRecordSet = objCommand.Execute. Error is "Active Directory: referral was returned from the server. "
Can someone tell me what i am missing
Subject: Problem accessing AD through ADO/Lotusscript
I have no experience with VB so what I will explain is generally the problem people have.
When you run a VB from the desktop, you use your account name (e.g. administrator).
The server, running as service, probably run as system account, so even if you are runing both on the same machine, they CAN have different rights.
HTH
Daniel
Subject: Running local…
Thanks Daniel,
I’m running the LotusScript manually as an agent on my workstation (same result from a button too) so it is all running as me.
I think you might be on the right track though in that maybe MS products like vbs and vb are able to assert my AD credentials in some way that Notes isn’t.
Regards,
Rob
Subject: RE: Running local…
I have a lotus script agent which I am running on the development server from my local workstation/machine. (Server machine has Admin login which has full access on AD server). Now I can read all entries in the AD but I cannot add any entry (user) to the test group. I am getting “213 - OLE: Automation object error”. Can anyone help me on why this error occurs and how can I fix it?
Hi Rob -
Gotta use set:
hth,
dgg
Subject: WHOOOO HOOO!! THANKS!!!
Thank you so much, that did the trick. I was beating my head against the wall with that one.
Best Regards,
Rob
