I found a Problem about set “Hide Paragraph” and “Paragraph Style” for rich Text when I did app development with Designer 801.
The Steps are:
Create a Rich Text Field
Double click the field
Choose “Hide Paragraph” Section, and click “Hide Paragraph if…” checkbox and fill the condition box with any condition
Then choose “text” option instead of “field”
Choose “paragraph style” section
choose a kind of style except “none”
Go back to “Hide Paragraph” Section, then you will find the checkbox you checked in step 3 is unchecked now.
Please help to check the problem. Thank you so much in advance.
