Private Calendar entry problem
When normal users want to open a calendar for another person this annoying problem appears.
When the entry (any entry : appointement, all day event, reminder, …) is private (mark private) the notes clients stops and an nsd file is generated.
Each time a user wants to control another calendar, the notes clients crashes !! I almost tested everything (replace design, grant access, modify preferences), nothing helps !
As I am an administrator, I can access every calendar without problem but my users cannot do this and they are becoming quite angry…
My users use the french notes client 6.0 or 6.0.1…
Has anybody already had this problem ? Is there a fix ? I’m becoming crazy…
Every idea would be appreciated. Thank you in advance…
Subject: Private Calendar entry problem
I am having the same problem. Users are delegated full access to a calendar, but when one of the delegated users tries to open the other person’s calendar entry, as soon as they switch to a date that has an entry marked private, the Notes client crashes and an NSD file is created. Does anyone know what could be causing this problem?
