Printing Problems
Ok,
What we have is a table that has a dark background color and the font over that background color is white, when we print the form you would think on a black and white printer we would get a dark line with the white font.
What we are getting is just a black line. The white font is not printing.
It happens in different databases and on different printers (different models).
Any Ideas what might be causing this? Have any ideas on what I could do to fix this (other then changing the background color)?
Thank you so much for your time and responses
Subject: Printing Problems
I’ve seen this same issue and never found a way around it.
Word docs can do this, I think because the bitmap generates empty (clear?) pixels in the places where the lettering / font is, but I don’t think Notes uses a similar mapping schema.
