hi all we recently upgraded our lotus 4.5 to 6.5.2 and have upgraded some of our clients to notes 6.5.2 and all the upgraded mail files use inotes6 as mail template . The recent problem i am facing is at the client mail box …say in inbox or send view the cursor is on a document and click file print (since need to print the document) it reports an error saying you cannot quit notes as some windows are opened.please close the window in a dialog box …opens a empty workspace and on clicking that a dialog saying insufficient memory click ok then close the window of workspace …and the document prints …
this problem i am facing in some clients only the others where able to do the same task without any error
can any one help me …
note : i did check the help and it says that insufficient memory dialog might appear if we have opened more that 9 windows …but in All the case that i was reporting i just have one window open thats my mail file
hope some one can help me to fix the problem
Thanks in advance
warm regards
Venki
