When I copy a section of an excel spreadsheet in Excel 2007 and then paste this information in a new memo in notes everything looks fine I can send the memo and the recipient can open and read it, but if they try to print the memo the excel content is a black box. Nothing is readable, just a big black box. This happens on version 7 and 8 of lotus notes. The only way around this is to copy the selection as a bitmap. This can be printed. Is there anyway to get this working without the workaround I mentioned?
Subject: printing embedded excel 2007 problems
Get the Excel 2007 update at: http://support.microsoft.com/default.aspx?scid=kb;EN-US;948954
it resolves the “Black Box” problem
Did you ever find a solution to this. I am seeing the same thing. When I print from DWA everything displays fine.
