Print settings (a novice) Question
Hi guys,
Say I have a view to be printed in landscape. I set the pagesetup print it in landscape.
I go to my mailbox and want to print in portrait which i do without changing the pagesetup.
What i am confused here is, is this print settings individualized for each database or how is it ?
Thanks a lot for all your responses.
Regards,
Arun.
Subject: Print settings (a novice) Question
Print settings are screwed up in R6. Landscape doesn’t work in R6 through the page setup dialogue box (WinXP client / Domino R6.x server).
You have to go into the printer’s properties and select landscape. Once you’ve done that its only set to landscape for that Print Job. Next time you print it goes back to the default Portrait.
To make landscape your default go to start>settings>printers and set the default ot landscape from there.
Changing the orientation from landscape to portrait in the Page Setup dialogue box in Lotus Notes R6 does absolutely nothing. If it did however, the setting would be retained for every subsequent print job, no matter which database you’re in.
Hope this helps.
ST
