I am trying to process a list of documents that were selected in a view. I have the following code:Sub Initialize
Dim docSubmit As NotesDocument
Dim varDocUNID As Variant
Dim docSelected As NotesDocument
Dim db As NotesDatabase
'Get the document that was submitted with the embedded form
Set docSubmit = session.DocumentContext
Set db = docSubmit.ParentDatabase
Print |<font face="Verdana">|
Print "Results"
'Get the field that contains the UNID’s of the selected documents (array)
varDocUNID = docSubmit.GetItemValue("$$SelectDoc")
'Make sure that at least one document was selected
If varDocUNID(0) = "" And Ubound(varDocUNID) = 0 Then
Print "No documents were selected.<BR>"
Else
If docSubmit.runagent(0) = "1" Then
'Loop through all the documents that were selected
Forall unid In varDocUNID
Set docSelected = db.GetDocumentByUNID(unid)
Print unid & "<BR>"
If Not docSelected Is Nothing Then
docSelected.current="0"
Call docSelected.Save (True, False)
End Forall
Print "<BR><BR>"
Print "The documents you selected have been processed"
Print "<BR><BR>"
Print |<Center><input type="button" value="Return to view" onClick="history.back();"></Center>|
Print |</Font>|
The “RESULTS” and unid values are printed (i.e. displayed on a web page) but the print statements that I have after the forall loop finishes processing all the docs does not print, it is missing in action. I can’t figure out why…
Any ideas???
Cynthia
