I have a strange problem. I have a web application and i can print a document attachment from a view. the code is :
Dim tDocuments() As notesDocument
Dim nNbDoc As Integer
Dim sNomVue As String
Dim d As Variant
Dim docid As String
Dim session As New notessession
Dim db As NotesDatabase
Dim tempdoc As NotesDocument
'on va recupérer l'id du document et le nom de la vue
Set tempdoc = session.DocumentContext
sNomVue= getURLParameter(tempdoc.query_string_decoded(0),"view")
docid="view"
unid=Instr(tempdoc.query_string_decoded(0),"listedoc=")
unid=Mid(tempdoc.query_string_decoded(0),unid+9,32)
'on récupère le nom du fichier attaché
Set db=session.CurrentDatabase
Set doc=db.GetDocumentbyunid(unid)
Call doc.ReplaceItemValue("StatutImpression", "Envoyé")
Call doc.save(True,True)
Set rtitem = doc.GetFirstItem( "Body" )
Forall att In rtitem.EmbeddedObjects
If att.Type = EMBED_ATTACHMENT Then
nom_fichier=att.Source
End Forall
Dim odoc As notesdocument
Dim sScriptJavascript As String
Dim sIdDoc As String
Dim aaa As String
aaa="http://dominodvt/intranet/drh/abcv/pomonaabcvcand.nsf/ViewAFaireCourriersAEnvoyer/"+unid+"/$file/"+nom_fichier
sScriptJavascript = "<script language =""javascript"" > "+_
" window.top.FrameImpression.location.href = '"+aaa+"'; "+_
" window.top.FrameImpression.focus() ; "+_
" window.top.FrameImpression.print(); " +_
" self.close(); " +_
" </script> "
Print sScriptJavascript
When we open the application and print an attachment, this code print a blank page on the first time we print.
But, if we don’t close the application and then we print again this code work very fine.
I don’t know how to resolve it. If you have an idea please help me.
