Print Order Problem
Using lotus script to pass through a view, I pass through each view entry and print. Print doc A, doc B, doc C, doc D, etc. When they ouput on the printer the order is not maintained. Once you get past some point in view entries they loose the original order and print out of sequence. Say A, C, B, D for example. The larger the number of entries the more they scramble. I have tried several different printers and get the same out of order printing. Any ideas?
