Print Header problem
Hello, I have a problem with print out document.
Is there any way to set up Header to print out title in two lines like below:
Form A First Line (page 1)
             Second Line              Number :1
Or Can we set up Page Break on the Notes document base on the different document?
Many thanks in advance.
Linda
Subject: Print Header problem.
In the Form Properties Box, in the Printing Tab (printer icon), you can set a Header and Footer to print for each document that is created by the form…
For two lines just enter one line, hit the ENTER key, enter the next line…
HTH,
Dan
Subject: RE: Print Header problem.
I see. Thanks Dan.
Linda :slight_smile:
