Print Function using winspool.drv affects other fields
I have a function that prints an embedded word document to our printer which has 4 trays. Depending on a particular variable, the document prints to different trays.
Since introducing the function, it is havng a knock-on affect on other simple functions, such as:
'# Calculate options for CAT Codes
If source.editMode = True Then
Dim x As Integer
doc.sCatCodeChoice = ""
Dim lossType As String
lossType = doc.sLossType(0)
Dim sess As New notesSession
Call getAdminDB( adminDB )
Dim catView As notesView
Set catView = adminDB.getView( "vM47" )
Dim catDocs As notesDocumentCollection
Set catDocs = catView.getAllDocumentsByKey( lossType, True )
Dim catDoc As notesDocument
Set catDoc = catDocs.getFirstDocument
While Not catDoc Is Nothing
    Dim lossDate As New notesDateTime( doc.dDateOfLoss(0) )
    Set startDate = New notesDateTime( catDoc.dStartDate(0) )
    Set endDate = New notesDateTime( catDoc.dEndDate(0) )
    If lossDate.lsLocalTime => startDate.lsLocalTime Then
        If lossDate.lsLocalTime <= endDate.lsLocalTime Then
            If x=0 Then
                doc.sCatCodeChoice = catDoc.sName(0)
                x=1
            Else
                doc.sCatCodeChoice = doc.sCatCodeChoice(0) & "," & catDoc.sName(0)
    Set catDoc = catDocs.getNextDocument( catDoc )
Wend
This is the function:
Declare Private Function DeviceCapabilities Lib “winspool.drv” Alias “DeviceCapabilitiesA” _
(Byval lpDeviceName As String, Byval lpPort As String, Byval iIndex As Long, lpOutput As Any, Byval dev As Long) As Long
This is called by:
Public Function GetBinNumbers(app As Variant) As Variant
'Code adapted from Microsoft KB article Q194789
'HOWTO: Determine Available PaperBins with DeviceCapabilities API
Dim iBins As Long
Dim iBinArray() As Integer
Dim sPort As String
Dim sCurrentPrinter As String
'Get the printer & port name of the current printer
sPort = Trim$(Mid$(app.ActivePrinter, InStrRev(app.ActivePrinter, " ") + 1))
sCurrentPrinter = Trim$(Left$(app.ActivePrinter, Instr(app.ActivePrinter, " on ")))
'Find out how many printer bins there are
iBins = DeviceCapabilities(sCurrentPrinter, sPort, DC_BINS, Byval vbNullString, 0)
'Set the array of bin numbers to the right size
Redim iBinArray(0 To iBins - 1)
'Load the array with the bin numbers
iBins = DeviceCapabilities(sCurrentPrinter, sPort, DC_BINS, iBinArray(0), 0)
'Return the array to the calling routine
GetBinNumbers = iBinArray
End Function
If I restart the client, the other functions work fine, until I call this print function. I cannot debug the functions that stop working, as this also seems to be affected.
Any advice/information at all would be appreciated.
Thanks,
Darren
