Print document problem!
Hello all,
I have a problem when printing my document on the web.I dont want my action buttons and some of the fields on the document to be printed.
I did hide these fields when printed but apparently it doesnt work on the web and also there is no way to hide the action buttons either…
So anyone who can show me a way to print the document the way i do will be really appreciated.
Thanks.
Subject: Print document problem!
There might be some way to do this with CSS2 but what seems to be more common is to have a link on your page that says something like “Printer-friendly version” when you click that link, you get the whole thing in a new window without the buttons. Basically, you need to make an alternate form for every existing form.
Subject: RE: Print document problem!
So can we say that there is no way to hide some fields and action bar buttons when printing a document, and the only way to do is to design a new form and open it when printing?..
It seems lots of silly work to do just to be able to print a document the way you want…I hope iris people aware of this…
Thanks anyway…
Check out @Media Print and @Media Screen in css stylesheets. This lets you specify what is displayed on screen and when printed, so you can set the style to display:none for the elements you do no want to appear
HTH
