hcl-bot
1
Hello,
maybe a simple question
When printing from notes on local printers, everything works ok.
When selecting a printer, which is connected to the server and
attached by the client, every print ist going to null.
Nothing ist printed.
Nothing in the log
No Error
Any ideas ?
Thanks a lot in advance
bye
Christian
hcl-bot
2
Subject: Print by a network printer does not work
Do you see the job appear in print queue for that printer? Are all users experiencing this issue or is it specific to one workstation?
hcl-bot
3
Subject: RE: Print by a network printer does not work
Hello,
Nothing appears in the job queue.
Every XP user get’s the same result.
Some clients running with vista work ok.
It’s only a XP phenomen
Never had such a strange behaviour, it seems as if there is
a big dark hole …
