Prevent Copying did not work on DWA & inotes
Prevent copying feature did not work on DWA or inotes. is there any third party or ini parameter or design changes?Please provide solution. It is very urgent.
Subject: Prevent Copying did not work on DWA & inotes
No, Prevent Copying is a feature that works only in the notes client, the Notes Client prevent the copying of any content. DWA is a Web Application, this type of functionality would need to be controlled by the browser. Since the browser doesn’t allow applications to prevent copying any content from the browser to the clipboard, DWA does not have such capability.
For more information:
http://www.ibm.com/support/docview.wss?rs=899&uid=swg21105134
I dónt know if there is a third party to accomplish this task, but I´m sure that is not an INI parameter you can add or modifiy, the prevent copying is an internal field of the mail form.
