Prb for fraeme n page.(pls go through) not the same as below
hi all.
Everything that needs to be there in the prj, exists, i min frm page, frameset, bt still some time showing Msgbox “not exist” for that particular page or/ and frameset, sometimes smoothly running.
can anyone xplain
Subject: prb for fraeme n page.(pls go through) not the same as below
nt sr ndrstnd yr prblm cmpltly
Subject: RE: prb for fraeme n page.(pls go through) not the same as below
c wat i ve mentioned is, in my db i ve the pg n the frame, bt wen i am tryig to acces dat page or frame through a hotspot it says dat, dat particular pag is nt found. agin sometime it is performing or executing properly.
dat is the problem.
Use COMPLETE words so we can read what you are writing.
in my project i have the pages and frames created, bt during execution sometime i find it shows an error message that “Page not found” or something lk from which you can understand that the error is for the page is not there, but if you browse in designer you will have the page frames all.
so now can any one please explain the reason…
No, still not.
Judging from the category you entered, this is for the notes client, not for the web browser, but the message doesn’t look familiar. Posting the exact error message you get (and how it is displayed) would be helpful.
Also, do you really just have pages (no forms, no views) displayed in the frames of your frameset? How did you tell the frame(s) what to display? There are a couple of choices available.
What access rights do users have to the application, if that error comes up? Is it always for the same pages, or is the error intermittent?
