I have a very simple requirement (or at least I thought it was simple). I am working with an outside company to expose a service for employment verification. Basically, they are going to send an XML message via an HTTP POST. SSL is a requirement. There’s no flexibility on either point, it has to be a POST with SSL.
In my testing, I have an agent that basically reads the Request_Content CGI variable and echos it back to the screen with a Print. No problem, as long as there is no SSL involved. The minute I switched on the flag “Require SSL Connection” on the database properties, this simple agent stopped working.
When I was debugging, I echoed a number of other CGI variables to the screen and I came across a strange thing. The Request_Method was different depending on whether SSL was being used or not. If Require SSL Connection is turned on, it appears to change my HTTP POST to a GET (even though the page I used to submit the request, clearly specifed that it was a POST).
Does anyone have a clue why it appears to be redirecting my POST to a GET and more importantly, how can I workaround? As I said before, POST is a requirement. Some sample code is below.
Thank you.
Mike
HTML Page in Database1, make sure that the Web Access → Content Type in the page properties is set to HTML
Prototype POST RequestPrototype POST Request
Paste XML here, replacing this promptParsing agent in Database2
Sub Initialize
Dim doc As NotesDocument
Print "<u>Request_Method</u><br>" + doc.GetItemValue("Request_Method")(0)
Print "<br><br>"
Print "<u>Request_Content</u><br>" + doc.GetItemValue("request_content")(0)
Sample output (where Database2 is not forcing SSL)
Request_Method
POST
Request_Content
request_xml=This+is+a+test
Sample output (where Database2 is forcing SSL)
Request_Method
GET
Request_Content
