Possible Solution
The local user policies have to be reset
  1. Backup the users names.nsf file
  2. Open users address book (names.nsf)
  3. Go to the hidden view ($Policies)
     a.	To go to this view, press and hold CTRL + Shift
     b.	Click on View -> Go To
  4. Delete all documents listed there
  5. Go to the current location document
     c.	Expand Advanced and select Locations
  6. Select the current location
  7. Click on Edit Location
  8. Click on Actions → Remove Address book preferences
  9. Click on Actions → Advanced → Set update flag
  10. Click on YES when prompted
  11. Save and Close the location document
  12. Restart lotus notes
I hope this helps, it helped me
Subject: Possible Solution to this problem
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/0dc2ae87fa1244c38525702f0075361d?OpenDocument
