Possible replication problem?
I am not sure if this is a problem with replication or not but I have exhausted all other possibilities!!
We have replication of certain mail files between 2 sites. one server is 5.0.11 (the site the user works at) and the other 6.5.1 (the Head Office site).
The replica at my Head Office site (6.5.1) seems fine (its replicated to this site for DR reasons) but the user at the other site (5.0.11) is saying his mail file has mails dissapearing out of it?
I have looked at both replicas and the one on the 6.5.1 server is much larger than the one on the 5.0.11 server?
We removed the replica from the head office site (6.5.1) and the user reported no missing mails in the week since we removed it?
Any ideas would be gratefully appreciated.
Many Thanks
Mark
Subject: Possible replication problem?
Hi Mark,
I’d compare document counts in the databases, not just database size…
Did you check the replication settings, such as the “Remove docs not modified in the last xx days”?
Subject: RE: Possible replication problem?
Hi Herbert,
Thanks for your response.
The ‘remove documents not modified’ is not ticked. Also, I did check the doc count - it was different by hundreds of docs?
Any other ideas?
I’m thinking “deletion stubs”…You could also try clearing the replication history and replicate again.
Are document deletions replicated?
Disappearing documents could be because of an agent, a user, the archiving function. But you already checked these, so I don’t know…
Thanks Herbert,
We checked Archiving and while the user does archive none of the missing mails ar in hi archive.
Also, no agents running. Deletions should be replicating?
Is a mystery.
