Possible Code Regression Found... Any thoughts for workarounds?
I have a call in to Lotus and they can not only reproduce the problem but think it’s a code regression after upgrading to 7.03…
I have an agent that acts Before New Mail Arrives (with code as old as the hills) that detaches a file from a message that arrives.
That’s it, nothing exciting.
This is the error in my log:
12/10/2007 07:08:14 AM Begin MIME to CD Conversion (Process: Router (00000B6C:00000012), Database: d:\Lotus\Domino\Data\DIR\dB.nsf, Note: 80000001)
12/10/2007 07:08:14 AM MIME to CD error (Process: Router (00000B6C:00000012), Database: d:\Lotus\Domino\Data\DIR\dB.nsf, Note: 80000001): Invalid or nonexistent document
12/10/2007 07:08:14 AM End MIME to CD Conversion (Process: Router (00000B6C:00000012), Database: d:\Lotus\Domino\Data\DIR\dB.nsf, Note: 80000001)
Here’s my response from IBM so far:
Its failing at the line:
    If ( rtitem.Type = RICHTEXT ) Then
After thinking about the issue. I’m not sure a work around is possible, code wise, because at this point in time the message is in MIME not richtext. I even put in a session.ConvertMime = True at the beginning of the code and session.ConvertMime = False at the end or before any exit sub and this does not seem to be converting the MIME. In the interim I would suggest either rolling back or altering the agent to get a handle on the new doc in the mail box and then perform the action. I tested the code as an agent selection while the document was open and it worked fine.
Here’s my code:
On Error Goto errtrap
Dim note As NotesDocument
Dim dbug As NotesLog
Dim db As NotesDatabase
Dim agent As NotesAgent
Dim n As String
Dim it As NotesItem
Set session = New NotesSession
Set sourcedb = session.CurrentDatabase
Set agent = session.CurrentAgent
n = agent.Name
REM Log steps in our processing for debug purposes
Set dbug = New NotesLog("Agent Log")
dbug.LogActions = True
dbug.OpenAgentLog
dbug.LogAction("begin")
REM Make sure we have the note set correctly
If db Is Nothing Then dbug.LogAction("db is not set") Else dbug.LogAction("db is set")
Set note = session.DocumentContext
If note Is Nothing Then dbug.LogAction("note is not set") Else dbug.LogAction("note is set")
REM Note the Subject of all messages
dbug.LogAction("Subject ->" + note.Subject(0))
If Instr(1,note.Subject(0), "CompA") <> 0 Then
	categ="CompA"
Elseif Instr(1,note.Subject(0), "CompB") <> 0 Then
	categ="CompB"
Else
	Print note.Subject(0)
	Exit Sub
Set rtitem = note.GetFirstItem( "Body" )
’ NO FILE ATTACHMENTS
	If note.HasEmbedded = False Then
		Print categ + db.Title + " - Agent ("+n+") error : sent email has no attachments"
		Set memodoc = New NotesDocument(db)
		memodoc.Importance = "1" ' *** Sets Importance to High
		memodoc.Principal=db.Title
		memodoc.Subject="ERROR: " + db.Title+ " Agent Error (" +categ+")"
		Set ertitem = New NotesRichTextItem( memodoc, "Body" )
		Call ertitem.AppendText(db.Title + " - Agent ("+n+") error : " & Err() & " : " & Error())
		Call memodoc.Send( False, "dBGroup" )
		Exit Sub
	Else
		Forall o In rtitem.EmbeddedObjects
			If ( o.Type = EMBED_ATTACHMENT )  Then
				oname$=o.Name
				Call o.ExtractFile ( "\\svr$\dir$" & oname$)
				dbug.LogAction("extract file")
				note.Category=categ
				note.FileDate=Filedatetime("\\svr$\dir$\" & oname$)
				Call note.Save( True, False )
’ FILE FOUND AND EXTRACTED
’ memodoc.Form=“Memo”
				memodoc.Subject=db.Title+ " Agent completed successfully (" +categ+")"
				Call ertitem.AppendText("Agent ("+n+") completed successfully >> ")
				Call ertitem.AppendDocLink(note, note.Subject(0) )
				Call memodoc.Send( False,"User1")
				Print "Doc Database - Agent ("+n+") completed successfully"
			Exit Sub
		End Forall
dbug.LogAction("done")
dbug.Close
Exit Sub
errtrap:…
No errors are generated BTW
Subject: Possible Code Regression Found… Any thoughts for workarounds?
I wonder if you are sending this to a mail-in database? ewe had just this problem, and went to the mail-in database definition document. I discovered that it as an option for mail preference - Rich Text or MIME. I had not noticed this before - maybe it was added in 7.0.3?
Subject: RE: Possible Code Regression Found… Any thoughts for workarounds?
I’m pretty sure this a bug.
session.convertmime simply doesn’t work in Before Mail agents — and it used to.
It’s definitely a Regression in 8.0.1 and is fixed in 8.0.2
see this:
http://www-10.lotus.com/ldd/nd8forum.nsf/5f27803bba85d8e285256bf10054620d/0dfcdfe2817c9d138525749e0002b0a3?OpenDocument&Highlight=0,convertmime
