Hello,I have posted twice this prob…nobody is replying me correct answer… plz help me out…
My problem is i have two locations created.I am switching location thru file->mobile->location.
This thing i am using for goping online and offline.
Now wen user is using application offline i want to track this thru lotus script.
Plz suggest any code thru which i can display a user that he is working offline and validation is not possible…
plzzzzzzzzzzzzz help me out…
Subject: Database Location
Is this database loaded on Web or Client or Both?
Subject: RE: Database Location
I am talking about client only…i have local replica of it on which i am working…
If it is local replica, Db.server returns ""Means you are working in your local Machine.
So you can stop validation for the db.server=“”
I tried this…but if i changes location from server to local in both the cases its giving messge…in both the cases it is taking server=“”…dunno y?plz help me out.
Subject: Plzzzzzzzzzzzzz help me…databse location
Actually the problem is…I am taking address books when i am connected to server…if no connection then it is unable to take address books…As set db=session.AddressBooks(1)
if i change location then it is giving error in this line only
its not checking further…
