I have a simple view setup with the calendar option selected that will be used by end-users on the web. I have added a css file to the style sheets section in designer, and the view uses a $$ViewTemplateDefault form. In the style sheet, the below code is used:
body
font-family: Tahoma,Arial;
table
height: 100px;
border: 1px solid black;
td
vertical-align: top;
border: none;
If you try this out, you will see that documents/entries will appear on a seperate line/row instead of the actual date box it should be in. How do I prevent this from happening. PLEASE HELP!!
Thanks in advance.
Mark
