In my web form, there is an Subject list field, It contains, so many text values. I need that once we select one text, then it automatically opens another form2, and must display that subject field value in form2 in query_String field. For this I know we have to use onchange event, bcoz i am not using any button to give simple @urlopen function.
So for this please give the onchange event script. Pls I am in big trouble.
Hope soon
Rajan
Subject: Pls help me, query_string using onchange
Do you see the “Browse by” and “Select view” drop down in the right hand navigator of this forum?
That automatically navigates to a different view using onChange event.
Try asking your browser to view the HTML source of the page to see how that was done:
<SELECT name=“URLpick” onChange=window.open(db+this.options[this.selectedIndex].value,‘_top’)>
Select view
Date (threaded)
Date (flat)
With excerpt
Author
Category
Platform
Release
Or try searching this forum. This question has been answered hundreds of times in this forum already.
try this in the onchange event:var selindex=document.forms[0].subject.options.selectedIndex
location.href = “http://www.xxx.com&Query=” + document.forms[0].subject.options[selindex].text;
Subject: RE: Pls help me, query_string using onchange
Hi Steve,
I was tried using ur example, but it is giving error
varselindex=document.forms0].SUBJECT.options.selectedIndex
location.href = “/lms.nsf/EmpIssueBooks?openform&Query=” + document.forms[0].SUBJECT.options[selindex].text;
— Below is error-------------
HTTP Web Server: Lotus Notes Exception - Entry not found in index [/lms.nsf/EmpIssueBooks?openform&Query=Chemical Engineering]
I also used below code inplace of above code, but this also not working
location.href = “http://10.1.1.92/lms.nsf/EmpIssueBooks?openform&Query=” + document.forms[0].SUBJECT.options[selindex].text;
Pls give me solution
Adv thanks
Rajan
