Please HELP ! Urgent!
Dear all,
Please HELP !!!
No route found to domain XXX.com from server ABC/SRV/DEF. Check Server, Connection and Domain documents in the Domino Directory.
Thanks !!!
Subject: Please HELP !!! Urgent !!!
Do you have a Global Domain Document? A value in the Configuration Document where Domino can relay internet mail to?
Did you search the forum?
http://www-10.lotus.com/ldd/nd6forum.nsf/Search?SearchView&Query=no%20route%20found&SearchOrder=0&Start=1&Count=100
HTH
Gregg
