Please Help......Script error
I have designed a database which involved the oracle connectivity as per the requirement and it works fine on my machine. Testing was successfully completed by me as a developer on my machine.
Now when i have given the same database to the user to go thru UAT (user acceptance test)process, the error comes when it tries to open a form.
Error message: Error loading USE or USELSX module:*LSXLC
precaution taken …
  1. No Double Declaration
  2. Proper Declaration of the script name in the option of the Globals of database.
  3. The NLSXODBC.DLL is present.
As the application is successfully running on my machine without this error, then why is it that the user’s are facing this error.
Suggest…
Adious ,
Nyssa C
Lotus notes developer.
Subject: Please Help…Script error
Are the Oracle drivers installed on the use’s pc?
What about the tnsnames.ora file on the user’s pc?
I don’t know for sure, but when I have received those errors I recompile the database using Tools>Recomile all LotusScript.
The errors go away when I do that…
Just a thought. Try it. I couldn’t hurt.
Subject: RE: Please Help…Script error
Hi Betsy -I think your dynamic table script is awesome, THANKS YOU!!!
I inherited an application that used your previous version of the dynamic
table.
I am currently updating the design with your new function, but I’ve run
into a road block. When I try to save the form, I get a script error
stating
“Not a sub or function name: GERERATETABLE”
Can you tell me where to find the generatetable function in the db?
Thank you,
Pat
patrick3.collins@prudential.com
The database involves 3 routing cycle, the 3rd person of the routing requires the database relative connectivity setting such as TNSNAMES.ORA & ODBC Driver setup on his machine so as he pushes the data into oracle…
my point of discussion is that do i require to have these setting at initiator’s level( which i think it shouldnt be)
this error message occurs while opening of the form, after the form is opened by clicking “ok” at every field on the form.
