Please, help on fixing view
Hi everyone,
Posted this yesterday => http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedweb/66e7da4678a2dadd8525741c004942dc?OpenDocument
Any ideas please?
Thank you
Subject: Please, help on fixing view
I believe the problem is your column formula:
@If(Form = “f.parent”; “Monthly Accomplishments”; “Activities” + “\” + Month + " " + Year)
While you look at the view and it appears the MonthID is before the Month + " " Year, it’s actually after. Therefore
Activities \ April 2008
Activities \ March 2008
and
Activities \ May 2008
ARE in the correct order.
A simple fix would be to append the month ID in front of the Month Name (because of October - November and December you want two digits in all cases)
@If(Form = “f.parent”; “Monthly Accomplishments”; “Activities” + “\” + @Right(“0” + @Text(MonthID); 2) + " " + Month + " " + Year)
You would now get:
Activities \ 03 March 2008
Activities \ 04 April 2008
and
Activities \ 05 May 2008
If you don’t want it to be like this then have a hidden column before 1, that determines the order:
@If(Form = “f.parent”; “Monthly Accomplishments”; “Activities” + @right(“0”+@Text(Month);2) + Year)
I guess you already have some sort of column at the start as you have Monthly Accomplishements before Activites, so the new hidden column would have to go after that.
Subject: RE: Please, help on fixing view
Hi Stephen,
Thank you for your patience and suggestion. It ALMOST worked.
I’ve been trying to fix it by myself, but no success.
Can you help me out there?
Here is what I did:
Column 1: @If(Form = “Monthly”; 50; 10)
Column 2: @If(Form = “Monthly”; “Monthly”; @Right(“0” + @Text(MonthID); 2) + Year))
Column 3: @If(Form = “Monthly”; “Monthly Accomplishments”; “Activities” + “\” + Month + " " + Year)
Column 4: MonthId
Column 5: never mind
This view is almost perfect, except that it categorizes “Activities” three times. It should appear only once (as showed in the previous post) and below it, May 2008, April 2008 and March 2008.
If I change place columns 2 and 3, I get the view below, which is the one that I want to, except for the months under activities that again are showed out of order (May, March and April, instead of May, April and March)
What am I missing?
Thanks once again,
Renan
