Thanks in advance
Subject: Please help me with the Java agent problem explained below
Not unless you link to it. (Oh, and the problem isn’t “explained below” at all. Where’s the code?)
Subject: Repost
Repost:I am writing a java agent that does a rich text search on a document collection then puts the results in a folder. I then open the folder from a return field in the form. This is for a web based application. The folder displays all available documents when it opens instead of just the search results. Any ideas?
Here is the java code:
Created on Jun 23, 2005
To change the template for this generated file go to
Window>Preferences>Java>Code Generation>Code and Comments
package com.tlcc.notes;
import lotus.domino.*;
@author kbrewer
To change the template for this generated type comment go to
public class RichTextSearch extends AgentBase {
public void NotesMain() {
try {
Session session;
DocumentCollection dc;
AgentContext agentContext;
Database db;
String title;
Document curdoc;
String srchtext;
String srch;
session = getSession();
System.out.println(session.toString());
agentContext = session.getAgentContext();
System.out.println(agentContext.toString());
db = agentContext.getCurrentDatabase();
System.out.println(db.toString());
title = db.getTitle();
System.out.println(title.toString());
curdoc = agentContext.getDocumentContext();
System.out.println(curdoc.toString());
srchtext = curdoc.getItemValueString("Search");
srch = srchtext;
System.out.println(srch);
View view = db.getView("SrchFolders\\Test");
dc = db.FTSearch(srch,0);
Document doc = dc.getFirstDocument();
while (doc != null) {
doc.putInFolder("SrchFolders\\Test");
doc = dc.getNextDocument(doc); }
view.refresh();
//view.clear();
/*dc.putAllInFolder("SrchFolders\\Test", false);
view.refresh();
String url = view.getHttpURL();*/
} catch(Exception e) {
e.printStackTrace();
