I have a need to strip out the hidewhens in a RT field.
I’ve litteraly removed the field from the form and added it back without any hidewhen formulas.
I have tried using LotusScript to create another instance of the RT field, remove the original RT field, and add it back.
Then I ran Refresh Selected Docs, but the hidewhens will not get removed.
Without purchasing Midas, is there anyway to fix this problem?
