I have problem using the Swing Integrator. I have a form(Form 1) with a subform(Swing Integrator), that inherit value from a selected document in a view. That document has a MS Word file attached on it using Swing Integrator.
Now, I used Form 1 to create a document, and then save it. Then i open the document, and click on the link, then an error occured:
Subject: Please help! Error using Swing Integrator
At my previous job, we found that when we placed Swing’s code into our applications we were constantly having to re-engineer and maintain the systems as soon as there was a new version of Swing or some other change in the environment. Lot of touch costs involved. Very messy.
We moved over to Integra for Notes which actually did more than Swing but left all database designs untouched. Also allowed us to run reports scheduled which was really nice. Sorry for the advert but am telling it as it is.
Subject: RE: Maybe this is the same we’ve had with Swing Integrator 3.11.000…
Are you using the same method as me?
Originally, that is, if i did not use the “inherit data from selected document”, if i click on the attached Word document, the document can open. But if the Word document was inherited, then it can’t open, wondering why.
Hello,
Our company provides support for all SWING product customers. We have a support staff that will be more than happy to assist you in solving your problems.
Therefore, please send your technical questions to support@swingsoftware. In addition, customers can access our Knowledge Base from our website.
