I’m on a form, NOT in a memo so @command([MailAddress]) is not an option. Is there a way to use @PickList([Name]) and have it display the cc and bcc buttons, not just an add button?
Any response is appreciated.
Subject: @PickList with a CC and BC? is it possible
@Command([MailAddress]) works on any form, you just have to give it names for SendTo, CopyTo, and BCC. Here is production code from my own apps that works flawlessly:
@Command([MailAddress];“NotificationTo”;“CopyTo”;“”)
Since I don’t give it a field name for BCC, that option isn’t displayed in the dialog.
Subject: RE: @PickList with a CC and BC? is it possible
“Since I don’t give it a field name for BCC, that option isn’t displayed in the dialog.”
If your form contains a field called BlindCopyTo and you want the above to work you need to provide the name of a field which does not exist on the form e.g. ([MailAddress];“NotificationTo”;“CopyTo”;“NoBCC”)
