Performance problems
We upgraded a domino R5.012 server to R6.5.1.
After the server upgrade we observe that, when the server has a lot of HTTP opened sessions at the same time (~150), the server processes HTTP requests in blocks every N secons (about 20 seconds) and each request of the block is processed in a long time.
Thank you in advance for any precious help.
Maria Grazia
Subject: Performance problems
Maria, Do you know if you are configured to run web agents concurrently? Check your Server Record/Internet Protocols/Domino Web Engine/Web Agents section for this setting:-jmw
Subject: RE: Performance problems
Thank you for your answer.
I checked the server configuration: if you intended the parameter “Run web agents concurrently?”, it is enabled.
Thank you in advance for any help.
Maria Grazia
