Performance Problems HTTP and LC LSX
We have just upgraded to Domino 6.5.3 and are experiencing severe performance problems. At this point, I can see a rsponse delay when using LC LSX within LotusScript. the longest delay is in the “fetch” process. That is, the SQL Execute goes OK and the fetch can take more than 3 minutes for a 3 row result set.
Secondly, we are seeing an extremely long delay to render the output page to the browser. This takes minutes as well.
Does any have any ideas? I have seen the posts about performance issues with agents, but they all seem to be with version 6.0.1. Is anyone else having the same or similar problems?
Subject: Performance Problems HTTP and LC LSX
I just finished building an application that uses LSX to access a DB2 storage. Although mine isn’t real-time fetching, I run the agent scheduled and it takes the agent about 2.5 minutes to select, fetch and create 1500 documents. And most of that overhead is in the part where Domino saves the documents.
Rendering the page depends on how many transactions the page makes to the server before it’s rendered. In our case, I had large views whose indexes were slowing down the process of loading the page, so I disabled indexing and am running updall on the database once a day.
In the LSX documentation, they mentionned that there are more efficient ways of coding the fetches specially if they’re successive. Maybe this technique could improve the efficiency of the transaction with the newer lsx class. (dll)
Aside from that, if you’re retrieving multiple rows in a single fetch operation, make sure the lsx version you’re using supports this feature.
Lastly, try posting in the Enterprise Integration forum. Most of the gurus post there. One of the most knowledgeable is Andre Guirard or something like that. He’s helped me out a time or two and knows the LSX very well.
