Overflow msg on block sender
I have an issue with a colleague. When he chooses Block Mail from Sender and he gets an Overflow message. I’ve checked the Calendar profile and the filter field is empty. I’ve re-applied the design template and checked mail rules. I can’t seem to find anything that would cause this. The debugger also doesn’t display on this prompt so I can’t even pinpoint the code that this is failing on. Has anyone encountered this?
Thanks,
Tina
