Out of Office replica problems
Hi gang! After having a look at the old answers in the forum about this topic, I still have some problems with this Agent.
Some users replicate to a Server, they enable the OOO and I can see it in that server how is running (no more servers in the net), after they return and disable the OOO, it still appears in the Domino Server Agents list. I have read that users must work directly to the OOO of the server on line? How can I do it? Do they need another profile (they’re Editors) for their mail database?
Many thanks for help and sorry for shooting again about this item.
best regards from Barcelona.
Marc
Subject: Out of Office replica problems
I too have recently seen this happen after upgrading the server to 6.5.4. The user (6.5.3) has editor ACL rights to their mail db and is using a local replica. From their local replica they enable OOO and this sets the OOO agent to run, which I can see is enable by viewing agents in their design on both the local replica and on the server copy. When the user returns and disables OOO using the local replica it disables the OOO agent on the local replica which I can see by viwing the agents in the design. However if I view the agents in design mode on the server copy the agent never get reset to disabled even after the user has replicated with the local copy of the mail db. Because of this the OOO agent is still scheduled to run on the server and the user continues to get the Welcome Back message reminding them to disable OOO.
Subject: RE: Out of Office replica problems
That’s it Rick ! … Did you solve it? How?
Has anyone got the answer for this scenario?
It seems that the server stands strong and even though the last change was made to the local copy to disable the OOO when replication takes place it will not amend the server copy.
This applies whether attempting to enable or disable the local to server.
