Out of Office problem
The problem is that OOF sometimes works and sometimes don´t work.I enable the agent OOF, and user1 uses the oof without problems, he enable and disable the agent. But later user2 want`s to use the agent and it don´t work.
What happens, is there any problem with OOF in lotus 7.0.2??
Please help me
Subject: Out of Office problem
Hi,please check the “Forum FAQ’s”. The goodess of agents , Julie Kadashevich , has put a lot of help there.
http://www-10.lotus.com/ldd/46dom.nsf/7e6c7e584a76331b85256a46006f083e/574c99ccb345839185256976004e811e?OpenDocument
HTH
Oliver
Check the schedule of the agent…is it set to run once a day…which would be 1 or 2am…or is it set to run after each new mail arrives. Click View, Agents, OOO, Schedule
If set once a day…then users won’t get the OOO response until after that time it runs.
