Other Problem with DXLImporter
Sorry, I have a New Problem!
If I import an DXL-File, I create some Tables!
My Problem is, that after import some numbers are false, that means 0,2083 → 0,2076 and 0,5729 → 0,5722!
But other numbers are correct imported, for example: 2; 2,0021 and 0,125 …
My Question is, wherefrom came this difference?
Or on which rule based it!
To beome this numbers, I export the new created document and look in the DXL-Text.
I hope, someone can help me, about this.
Subject: Other Problem with DXLImporter
I guess those numbers are inches. It converts to twips (× 1440) and truncates the value instead of rounding correctly. On converting back (÷ 1440), you sometimes lose a twip. For example:0.2083 in → 299.952 twips → 299 twips → .2076 in
Subject: RE: Other Problem with DXLImporter
Thanks!!!
This art of answer I hope to become!!! :slight_smile:
So I can prognosticate, which number will be change and can it prevent.
