Subject: Update !!
Hi Stanton, thanks for your reply.
I’m now receiving this error, after disabling “remoteServerOverride”.
Create a new OpenSocial is still not working.
But there are new are messages when I try to open " Test Gadget and Container Domain Configuration"
ERROR The requested URL could not be retrieved The following error was encountered while trying to retrieve the URL: http://localhost.ad.XXXX.net:2076/fiesta/notesdomino/notesdominocommoncontainer.html http://localhost.ad.janderijk.net:2076/fiesta/notesdomino/notesdominocommoncontainer.html Connection to 127.0.0.1 failed. The system returned: (111) Connection refused The remote host or network may be down. Please try the request again. Your cache administrator is ict-servicedesk@XXXX.com. Generated Tue, 06 Aug 2013 18:19:05 GMT by barracuda.ad.XXXX.net (http_scan_byf/3.1.12.1)
AND This is de Trace Log
Trace Viewer
en-US
Viewer Preferences <>
Time
Thr Id
Severity
Source Class.Method
Message
Subsystem
20:17:06.320
0
CONFIG
com.ibm.rcp.core.internal.logger.frameworkhook
writeSession
eclipse.buildId=20130228-1411
java.fullversion=JRE 1.6.0 IBM J9 2.4 Windows 7 x86-32 jvmwi3260sr12-20121024_126067 (JIT enabled, AOT enabled)
J9VM - 20121024_126067
JIT - r9_20120914_26057
GC - 20120928_AA
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -dir ltr -NPARAMS /authenticate =C:\Program Files (x86)\IBM\Notes\notes.ini -RPARAMS -personality com.ibm.rcp.platform.personality -product com.ibm.rcp.personality.framework.RCPProduct:com.ibm.notes.branding.notes -plugincustomization C:/Program Files (x86)/IBM/Notes/framework/rcp/plugin_customization.ini
Command-line arguments: -os win32 -ws win32 -arch x86 -dir ltr -NPARAMS /authenticate =C:\Program Files (x86)\IBM\Notes\notes.ini -RPARAMS -personality com.ibm.rcp.platform.personality -product com.ibm.rcp.personality.framework.RCPProduct:com.ibm.notes.branding.notes -data c:/Program Files (x86)/IBM/Notes/Data/workspace -plugincustomization C:/Program Files (x86)/IBM/Notes/framework/rcp/plugin_customization.ini
20:17:09.861
1
WARNING
com.ibm.rcp.managedsettings.internal.UpdateJob
getProvidersToUpdate
CWPMS0008I: com.ibm.collaboration.realtime.policy.sametime.managedsettings.ManagedSettingsPolicyProvider is not currently available.
20:17:11.692
2
WARNING
NLS unused message: // in: com.ibm.collaboration.realtime.ui.strings.messages
org.eclipse.osgi
20:17:11.720
3
SEVERE
Problems occurred when invoking code from plug-in: “org.eclipse.ui.workbench”.
java.lang.NullPointerException
at com.ibm.collaboration.realtime.magiccarpet.MessageEventAdapter.registerEventListener(Unknown Source)
at com.ibm.collaboration.realtime.login.LoginEarlyStartup.doEmbeddedLogin(Unknown Source)
at com.ibm.collaboration.realtime.login.LoginEarlyStartup.earlyStartup(Unknown Source)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(Unknown Source)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(Unknown Source)
at org.eclipse.core.runtime.SafeRunner.run(Unknown Source)
at org.eclipse.ui.internal.Workbench$54.run(Unknown Source)
at org.eclipse.core.internal.jobs.Worker.run(Unknown Source)
20:17:11.722
3
SEVERE
Unhandled Exception
org.eclipse.ui
20:17:11.723
3
SEVERE
Unable to execute early startup code for an extension
20:17:52.534
4
WARNING
com.ibm.fiesta.notes.internal.cache.RemoteHttpCache
CLPEE2008W: The centralized cache setting is empty.
20:17:52.822
5
WARNING
com.ibm.rcp.fiesta.service.internal.HTTPUtils
doPost
http://localhost:63393/fiesta/rpc http://localhost:63393/fiesta/rpc is responding slowly. 7 ms.
com.ibm.rcp.fiesta.service.internal.FiestaServicePlugin
20:17:52.842
5
WARNING
doPost
CLPEE5020W: An error occurred making a request to the server
java.io.IOException: Server returned HTTP response code: 503 for URL: http://localhost:63393/fiesta/rpc http://localhost:63393/fiesta/rpc
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection$6.run(Unknown Source)
at java.security.AccessController.doPrivileged(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getChainedException(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at com.ibm.rcp.net.http.internal.protocol.HttpURLConnection.getInputStream(Unknown Source)
at com.ibm.rcp.fiesta.service.internal.HTTPUtils.doPost(Unknown Source)
at com.ibm.rcp.fiesta.service.internal.HTTPUtils.doPostToFiesta(Unknown Source)
at com.ibm.rcp.fiesta.service.internal.HTTPUtils.doApplicationJsonPostToFiesta(Unknown Source)
at com.ibm.rcp.fiesta.service.metadata.GadgetMetadataRequestJob.run(Unknown Source)
Caused by: java.io.IOException: Server returned HTTP response code: 503 for URL: http://localhost:63393/fiesta/rpc http://localhost:63393/fiesta/rpc
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.ibm.rcp.net.http.internal.protocol.HttpURLConnection.reAuthenticate(Unknown Source)
… 7 more
20:17:52.844
5
SEVERE
run
CLPEE5001E: Error retrieving the gadget(s) metadata.
… 7 more
20:17:52.848
5
SEVERE
… 7 more
20:17:52.849
5
SEVERE
com.ibm.rcp.toolbox.opensocial.provider.internal.OpenSocialModule$OSMetadataRequestFinished
finished
CLFWW5004E: Gadget metadata request encountered an error: Server returned HTTP response code: 503 for URL: http://localhost:63393/fiesta/rpc http://localhost:63393/fiesta/rpc
com.ibm.rcp.toolbox.opensocial.provider.Activator
20:17:52.849
5
SEVERE
finished
… 7 more
20:17:52.850
5
SEVERE
… 7 more
20:17:53.840
2
SEVERE
com.ibm.rcp.toolbox.opensocial.provider.internal.wizard.OpenSocialDownloadPage
loadPage
