Opening of frame link in another frame
Hello frens, I’m facing a problem related to frameset…Actually I made a frame set in which there are 2 frames frame4(upper frame) and frame5(lower frame).Upper frame contain a searchform which contain a listbox and whose coding I’m enclosing here.Now I want that on selecting any option from listbox in upper frame the required form or page will get openend in lower frame but it is not opening in lower frame infact it will get opened in the whole page.
Can anyone solve this problem of mine…
I’m looking for any help
Please try to solve my problem asap.Thanx in advance
Kanishka
This is the coding of upper frame and lower frame contains nothing :
Read journals as McKinsey Quarterly
<td align="middle" height="37" width="200">
  <p align="left"><font face="MS Sans Serif" size="1"><b>Search anything Related to Project:<br>
  </b><select style="font-family: MS Sans Serif, Arial, Helvetica; font-size: 8pt; color: #000000; background-color: #ccccff" onchange="goSelect(this)" size="1" name="m">
By Project Banker Bank Technology IBS McKinsey Quarterly
  </font></td>
Subject: opening of frame link in another frame
1.You can set “default target for links” for your upper frame. This may affect other stuff, though.2.Try changing
top.window.location=options[selectedIndex].value; // jump to that option’s value to
parent.frame5.location=options[selectedIndex].value; // jump to that option’s value
HTH,
Simeon
