Opening a form problem
i have aform called forma i created document when i opened that document in the view
i want to open that document in a tabbed table structure
means all fields in the document should appear in tabbed table
Subject: RE: opening a form problem…
Will you please describe your problem more precisely? Why don’t you just put a tabbed table on your form and put the fields in the tabs? What’s the difficulty?
