Open XML page with embedded view problem
Hi there,
I created a simple form(no xml tag) and a view with XML tag in each columns. Then I embeded the view into a page contain XML tag and included the xsl stylesheet. All elements’ advance property is set to treat as HTML. It should work, right? The browser should do all the work. As far as I have been readying, I do not need to create any javascript or lotusscript to transform the xml .
But I can’t seem to be able to open xml with styles I have in xsl sheet on web. The sample databasethat I download from IBM (IBM Developer) also has the javascript and lotusscript agent to transform xml still did not work too. I don’t know what I missed. Anything to do with browser, plug-ins, version?
Anybody please help,
Thank you very much,
Pat
