OOO Replying even though sender has asked not to
Hi we are running version 8 when a user sends a message to other internal users with the option " Do not notify if ooo" ticked
The system still sends a notification.
Has anybody seen this before.
Subject: Running OOO agent or service?
And is this repro for you?
We haven’t seen problems with this, in either the OOO service or agent, and I can confirm that this is working correctly in both environments in R8.5 and R8.5.1.
Can you reproduce this failure? I.e., does it fail consistently? If so, can you check document properties on saved copies of the emails where you’re using “Do not notify me if recipient(s) are running OOO” – these should include an item $AutoForward=1, which will signal both the OOO agent and service not to send notifications.
