OnBlur problem
Hi,I am a newbie with LotusScript and have a problem with OnBlur for a ComboBox in a form I’ve created.
I have a field called Profiles where the user must choose a value. If they leave it blank they get an error message.
All this works fine but how do I get the focus back on the Profiles field?
Sub Onblur(Source As Field)
If CurrentField = "" Then
	Msgbox "You must choose a profile", 48, "No profile was choosen!"
	Continue=False
Brgds,
Hans
Subject: OnBlur problem
Call notesUIDocument.GotoField( fieldName$ )
Regards
SKS
Subject: RE: OnBlur problem
Hi,Thanks, found that part but still…
my script looks like this:
Dim uidoc As NotesUIDocument
Set uidoc = workspace.CurrentDocument
	Continue=False
	Call uidoc.GotoField("Profiles")
The MsgBox runs as it should but the cursor goes to the next field in the form and I can continue without choosing a profile and I get prompted to choose a profile even when I do???
Any ideas??
Brgds,
Hans
Try this
Msgbox “You must choose a profile”, 48, “No profile was choosen!”
Call uidoc.GotoField(“Profiles”)
Continue=False
