I Reinstalled IBM DB2 drivers! ,NOT the old ODBC lotus drivers...
I Just had to look at the IBM iaccess software, and noticed that the package is still listed as v1.1, but has been updated. PLease make sure you get the latest release. Also note that if you only need the drivers, there are separate packages available with ODBC drivers for the different platforms.
I found the correct downloiad link on the page https://www.ibm.com/support/pages/obtaining-ibm-i-access-client-solutions
You need an IBM ID. The IBM ID needs to be the same with wihich you can download updates to the IBM product you are connecting to.
Good morning everyone.
yesterday at a second customer who has db2 connected to lotus, i finally solved!
I found that it was enough to uninstall the domino server (from windows programs) and reinstall everything (domino + language pack + fp + traveler ..).
It's very strange as a thing but this is how it works!
At this customer I had the opportunity to create a test environment on a second test server: there, by installing domino 11 and connecting to the same client db2 with the same odbc driver, everything worked immediately; but when, in the actual environment, I updated domino from 10 to 11 ... boom! Same problem as the other customer! :-((
So I said to myself: what is the difference between the test environment and the actual one?
The difference is that in the test environment I had installed a "new" domino version 11 server, while in the actual environment I had upgraded a version 10.(just like what happened from the first customer months ago)
From there the idea of uninstalling all domino (obviously keeping the notes.in file and the domino \ data) and reinstalling from scratch.
If you need to, you know how :-)
Great to hear you have solved it. Thank you for sharing your solution!
