ODBC problem
I have problem in aagent where ODBC connection created, this agent run since so many years but suddenly it show problem “LS:DO- ODBC could not complete the requested operation.” , so i have checked connection on this server and connection is ok but still it show problem at line
Call con.connectto(dsn, userid, pass) where DSN=“TOS”, userid="dba and pass=“sql” , it show below error
My Simple agent is →
Sub Initialize
On Error Goto errH
Dim con As New odbcconnection
Dim qry As New odbcquery
Dim result As New odbcresultset
Dim dsn As String
Dim userid As String
Dim pass As String
dsn="TOS"
userid="dba"
pass="sql"
Set qry.connection = con
Set result.query = qry
Msgbox "Hi"
errH:
Msgbox "Error found in Initialize at line No : "+Cstr(Erl)+" Error details as follows : "+Error$
Can any one help in this problem
Subject: ODBC problem
OK so let think about what has changed. Is this a scheduled agent?
Is the agent signed correctly.
Here are some urls that describe thsat issue
http://www-01.ibm.com/support/docview.wss?uid=swg21515245
Are you really running 7.03 ? Not supported by IBM anymore.
If it really is client did they download any MS patches that might have caused this issue?
Subject: RE: ODBC problem
Thanks i got my problem solution and it was ok now
Subject: And what was your solution?
It’s kind of selfish to ask for help, but then not share how you resolved the problem, so that others in the future who may have the same problem can resolve it.
