Number increment- Need Help
I have a field in my document called “rev#”.I want to create a button that would create a copy of the existing document that has say rev# = 1, and then modifies the field Rev#=2. This way I will vae two documents one with rev#=1 and the other with rev#=2.
I was able to use “simple action” with copy to database to create a copy. Now I need help to chage the rev #. I can have the author do this manually. But I can not trust them to do this.
Any help will be appreciated
Subject: Number increment- Need Help
In simple action only you can add one more action to modify the field.
Regards
Rosie
Subject: RE: Number increment- Need Help
I am unable to do a mathematical operation in " modify the field" any sugessions?
