NSD is running, Notes crasches when trying to print
Our users access Notes via Citrix Program Neighborhood - it frequently happens that the above mentioned problem occurs
Subject: NSD is running, Notes crasches when trying to print
Hi, in the Notes.ini file we have encountered that by removing the STARTUPDB= resolved the issue.
Also, do you have the correct print drivers?
HTH
